RV10Rob
I have the standard MT governor on my RV-10 (IO-540-D4A5). I had the max RPM set to 2700 RPM initially, but over time it has been declining slowly, to the point that it's about 2640 on climbout now, at 2+ years and 200+ hours. Is that to be expected (i.e. I should just adjust the stop screw) or is this indicative of a problem requiring further investigation? The governor appears normal and in all other respects operates normally. Thanks...
-Rob
-Rob
