My RV7 has the 200hp A1B6 IO360, Sam James cowl, and the required 2 inch prop extension. All of the above left with an aft CG of 76.89. Plane flies a little nose heavy..controls are a little heavy, lots of up trim on final, and possibly a little extra fall off passing inverted on ballistic rolls. Thought I would start by moving the 15lb PC680 from Firewall to just behind the rear baggage compartment. That will move the CG about 1" aft. Any suggestions on other changes ? What is the safest and best mounting technique for the new location ?
Thanks for the thoughts !
Pete
N267RV RV7
Pete
N267RV RV7
