My Mistake
Since I recently did this (approx 1200 mi)--I'll chime in here. I had a Budget 26 footer (approx $650, 4 days, unlimited miles). This size truck is a VERY rough ride since, as already pointed out, it is essentially empty with one of our RV's in the back. A smaller truck will ride better--but it's very hard to cram airplanes in and protect from damage at the same time.
The fuse was set on furniture pads (no gear) with a pair of folded pads under the small end so it would set level. Three ratchet straps from the wooden false spar and the tail bulkhead to eyescrews in the truck floor held it very tightly--and perfectly.
The wings were wrapped in furniture pads and put in the original crates. The crates were strapped to the truck wall and blocked at the bottom (2X's screwed to the truck floor). No problem.
The emp parts and wing tips were wrapped carefully and set on edge in convenient spaces. These parts travel best on edge--this was second emp move for me. No problem.
The finish kit was in the original Van's crate. Crate was set against the truck wall and held there by 2X blocks (stacked 3 high) screwed together/to the truck floor. We did not fasten the crate down nor replace all the screws in the crate lid, unfortunately.
Herein lies my bitter lesson that might save someone some grief. You must understand that these parts, crates, airplanes will bounce 1-2 feet in the air in these trucks if not fastened DOWN tight, very tight.
The finish crate bounced up on 5 1/2" of blocks which twisted the whole thing, popped the lid completely off (see above--screws, lid
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
,etc.) and damaged/ruined the new canopy inside.
