R rwarre Well Known Member Aug 5, 2020 #1 Do the conical and dynafocal mounts have identical hole spacing when bolting to the firewall?
R Ralph Inkster Well Known Member Aug 5, 2020 #2 Per the plans they should be the same dimensions, but each mount may vary ever so slightly due to the welding process. Also be aware there were some models that had slight different depths (engine distance to the firewall). Last edited: Aug 5, 2020
