I'm mounting the governor on my IO-390 (RV-14A) and I thought I needed to include a AN960 -516 and an MS35333-41 washer under the nut. The Hartzell governor manual says to allow at least one thread extending past the nut. If I install the above washers the stud ends up flush to the nut.
I had a look on Van's 360 degree view of their install and there appears to be only one washer. I assume they installed theirs with only the internal tooth lock washer and no flat washer.
Any insight as to the procedure of installing a prop. governor would be welcome.
Thanks Ron
Thanks Ron
