Piper J3
Has anyone noticed an interference with the GPS-2020 antenna wires passing through the F-1201Z retaining plate?
There is a large hole in the retaining plate but it is extremely off-center with respect to the wires protruding from the bottom of the Skyview GPS-2020 antenna. The wires actually interfere with the edge of the clearance hole and the aluminum plate can easily cut through the wire insulation.
