Dan 57
Pretty happy with the install and operation of the Mountain High O2 system, works perfect ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Page 8 of the manual states: BLEEDING THE REGULATOR, Remove the regulator outlet tubing from the EDS inlet fitting.
Having read another manual for the older version of the unit, it said to switch it ON/OFF for a few times (yes, bottle closed...) until all the pressure is out.
Since it is more convenient than removing the tubing, I was wondering if there is any wrongdoing by using this method... any takers?
