This may be, but I have a great "mechanic" that I use for my automobile repairs. He is a great mechanic. Considering, as an experimental aircraft owner, I could have him work on my airplane whenever I wanted to, I think it would do a disservice to any conversation to lump the work that he would do as my "mechanic" in with the same context as I would when discussing what my "A&P" did while working on my aircraft.Actually Brian is correct.
The A&P's certificate is for "MECHANIC".
He may be rated for Airframe and/or Powerplant.
Why not just call the person a mechanic? If they are not you, and they are working on your plane, it is assumed they have the appropriate credentials
Just wondering why everyone likes to refer to A&P's rather than just "mechanic"
This is just one reason I got out of A&P work in 1997 and have been doing HVAC TECH work ever since. We were "just" mechanics, a dime a dozen and paid accordingly. I went to HVAC tech school for two years in Atlanta and make 50% more working on your home air conditioning system.
However, I don't expect the practice of calling him/her an A&P will change anytime soon. The term has been in practice for many decades.
Crazy.... and nobody dies if a nut goes missing. Smart man....
Actually, in the early days, HVAC equipment used Ammonia Gas and a missing nut could kill an entire Office Building!
Dkb
In New Zealand and Australia, and probably other countries, the title is Licensed Aircraft Maintenance Engineer. The short title is "Engineer". Unfortunately, the abbreviation is L.A.M.E.
I guess I believe folks use the term A&P deliberately, meaning:
1. "My Pilot buddy said I should use that in the fuel system."
2. "My Mechanic says it is OK to use that in a fuel system."
3. "My A&P said never use that in a fuel system."
So, do you use it or not?
Dkb
Well, if you are referring to experimental aircraft the answer can be yes. It is not a requirement that one have an A&P certificate to be able to legally work on an experimental. Anyone can do so. On the other hand, getting an airworthiness sign off in the logbook after the work is completed requires either a signature from an A&P or an owner/builder who holds a repairman certificate for that aircraft.okay, maybe i'm missing something, do people use mechanics that aren't a&p rated?
that's a foreign concept to me
Ok, Paul, I stand corrected. Airworthiness is only signed off during the Conditional Inspection. Although, having the repairman certificate, I do sign the "maintenance records" in a logbook after any maintenance work I perform. As Walt eluded to, I feel it important that the record be preserved for future reference if needed. A prime example is the recent directive from Vans that we check for missing spar bolts at the wing attachment. I have made an entry in the records to reflect that the plane has been inspected and the bolts were installed. Signed and dated with my repairman certificate information in the record. That way if Walt, or anyone else, has to deal with the airplane he can see the history. Now whether Walt would want to trust the information is surely his call to make. But it is there none the less.Oh dear....once again, we have a misconception. There is only one thing that is required to be in an Experimental Aircraft's maintenance records (it doesn't need to be a logbook) - that is the annual "I Certify that this aircraft has been inspected......and is found to be in a condition for safe operation" sign-off - and that must be by the person holding the Repairman's Certificate for that airplane, or a licensed A&P. No other records are required (although as an engineer, I certainly do much more), and no "sign-offs" are required by anyone. If you DO keep detailed records along the way, of things that you do (good for you!), anyone can sign them off, since the signature dosen't really mean anything.
This stuff drives A&P's nuts BTW (and rightfully so) - the rules for Experimentals are totally different than the certified birds that they have been tried to maintain "by the book".
Paul
Ok, Mel and Paul. I will refrain from commenting on issues that rely heavily on using the correct syntax in order to be accurate. My syntax has never been known to be very good no matter what the topic may be.Uh-Oh Steve. Don't quote Paul and then in the same sentence call it a Conditional Inspection.
He will be the first to tell you that there's nothing conditional about it. It is a Condition Inspection!
Paul
Paul,
I'm not so sure about this, what is your reference for not having to record maintenance? They may be experimental but they still have airworthiness certificates.
According to 43.9
? 43.9 Content, form, and disposition of maintenance, preventive maintenance, rebuilding, and alteration records (except inspections performed in accordance with part 91, part 125, ?135.411(a)(1), and ?135.419 of this chapter).
(a) Maintenance record entries. Except as provided in paragraphs (b) and (c) of this section, each person who maintains, performs preventive maintenance, rebuilds, or alters an aircraft, airframe, aircraft engine, propeller, appliance, or component part shall make an entry in the maintenance record of that equipment containing the following information:
(1) A description (or reference to data acceptable to the Administrator) of work performed.
(2) The date of completion of the work performed.
(3) The name of the person performing the work if other than the person specified in paragraph (a)(4) of this section.
(4) If the work performed on the aircraft, airframe, aircraft engine, propeller, appliance, or component part has been performed satisfactorily, the signature, certificate number, and kind of certificate held by the person approving the work. The signature constitutes the approval for return to service only for the work performed.
Paul,
Oh yea, I guess it's just so ingrained in my aviation psyche that all work be documented, I overlooked this exclusion.
While I certainly AM just a flying monkey, I am proud of the fact that I earned the privilege to call myself an aviator.
mine is a certified aircraft.
And with engineers. Take an 8 week IT technical seminar - and you're an "engineer"....
I liked the comment on Accountant vs CPA. That's really the perfect analogy. I'm the former, but never took the time to get the latter. Those that did really earned it. ...
I agree, engineer doesn't always mean much.....
