Seems to be a lot of confusion over my question which I thought was fairly straight forward, but I'll try again, with more info.
For the record, I have a -7a. I also have a weight and balance spread sheet, have completed my empty weight cg caculation, and have played with the numbers to see the effect of changing the various variables.
While I have run the numbers for various scenarios using MY weight, it is my understanding that for most forward and most aft CG calculations, one should document the calculation using the FAA "standard" pilot/copilot weights of 170 lbs. Therefore, for most forward CG, I have used full fuel, 170 lb pilot, no passenger, and no baggage. This puts me well within the accepted forward CG limits. If I change the pilot weight to my weight, I am still well within the limit. There is really nothing else to do to make my CG more forward, short of reducing the pilot weight further.
For the aft CG condition, it gets more interesting, as it is possible to exceed the aft limit with numerous variations of pilot/copilot weight and baggage. For example, using 170 lbs for both pilot and passenger and max. baggage (100 lbs) I must have 7 gallons or more of fuel on board to stay within the acccepted aft CG limit. Heavier pilot/copilot exacerbates the conditon.
Im confident I have a handle on this. The only issue for me is that there are an infinite variety of ways to each the aft CG limit in my case, but I need to document the most aft weight and CG condition for my inspection. If I can fix my minimum fuel value, then that just leaves me with the baggage to vary until I determine the max amount without exceeding the aft CG. So, once again, is there an accepted minimum fuel value I should use?
Hope this is more clear.
erich
