randylervold
moderator
How about a bit more RV-3 performance trivia to help pass those long winter evenings?
Last time I posted an EFIS screen that documented the cruise efficiency of the RV-3 with MPG as the metric, and you may remember that at altitude I can always get in the low 30s. Today we had a break in the local weather so I went out and flew two configurations that show two other corners of the RV-3 performance envelope... let's take a look.
Flat out top speed
Flying with the throttle and prop all the way forward and the mixture set about 75? ROP for best power it'll do 222 mph TAS, which matches my previous testing exactly. I suppose 13.3 gph isn't too bad for this speed but note that this computes to only 16.7 mpg, not very efficient. Nice to know how fast you can go though.
Lowest possible fuel consumption
Here's the "low & slow" configuration, note the RPM, MAP, and fuel flow. This computes to 39.1 mpg (statute). Who needs a Cub when you can fly and RV-3 along at 137 mph burning less fuel!!
Yea, I know, I'm biased, I think RV-3s are just the coolest little planes around. Just can't contain myself sometimes.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Flat out top speed
