I am trying to provide slack in connections between the engine (moving about) and the engine mount (not moving about). Usually this is easy enough. But, the starter cable is 2AWG and plenty stout. Is the connection I am showing below going to cause trouble down the line as the Adel clamp on the engine vibrates with the engine and the clamp on the engine mount does not, as much?
If so, do I just try to provide more of a loop in the 2AWG between the Adels?
![Starter Cable Secured.jpg Starter Cable Secured.jpg](https://vansairforce.net/data/attachments/23/23506-7b72e948112417957217347651e54584.jpg)
