Wesael
On a trip not long ago I took some screenshots showing the the TAS speed change while flying through high moisture air (clouds) and dry air (clear).
The first one is after about 30min of flight level in smooth IMC conditions.
This one is about 20 min latter after flying in clear air and drying the airframe off.
There are some subtle differences in, DA, MAP, CHT, EGT, FF, etc. but from the time the first shot was taken and the second shot there was no change in the power, prop or mixture settings.
Note the True Air Speed difference.
