Norman CYYJ
How many of you are using straight mogas in your RV and what size engine do you have? And what troubles if any are you having? What octane are you using?
Some States (in the USA) that have laws requiring ethanol in the gas also allow ethanol free gas at wholesale 'fuel farms'. ..., and this is a way I found to get ethanol free unleaded regular and unleaded premuim mogas in Western Washington.
I have an O-360, 8.5:1 pistons, that uses 91 octane mogas locally and 100LL when on the road. I have no concerns about the ethanol blended fuel. 3 1/2 years and 625 hours with no detectable problems. Dan
I used the rubber gaskets on the fuel senders and the autofuel made them swell and leak, I sealed them with the proseal tank sealer when I installed them but it didn't stop the autofuel from attacking them.
Mark & Normand in YYJ
Here in Canada,a friend of mine called the Technical Lab of Shell, Esso and Ultramar a few weeks ago and ask the head chemist if there was any ethanol in Mogas in Canada and his answers were than there might be up to 10% Ethanol in Regular Unleaded gaz but that it was impossible to get the High Octane level in Premium MOGAS if they used Ethanol ( I will assume it is the same in the USA. ) so it will be a safe bet to say that there is no risk in using ''PREMIUM Mogas'' in our engines.
Everytime I checked there wasn't any..
Bruno Dionne
[email protected]
IO550-N in my F1Evo. 100LL in one tank; premium MOGAS in the other. I figure there is E10 in the MOGAS,...
(Frank, I know you don't run an engine driven fuel pump, so this doesn?t really apply to you.)I wouldn't be using any ethanol with a mechanical FP unless I was sure the diaphram and seals were compatible.
Frank
Hey Dean..
Thank you for your comments as you seem to know what you're talking about but please don't shoot the messenger would you, I was just mentioning info that was pass on to me..
Bruno
The statement about alcohol not being in Premium mogas is definitely in error, at least in Mississippi. Both of my 'clean' stations recently started adding alcohol; one of them hasn't yet placarded their pumps. I only use premium, & I always check.
Charlie
(found 2 other good stations, though...)
Maybe the statement is unclear.
Ethanol is mandated except it is not mandated in premium fuel. Premium fuel may or may not have ethanol. I suspect around here it is in all fuels due to lousy EPA air quality.
Frank
