Oh yeah...the MOA thing. I never understood it to be an area you were required to talk in or even monitor. Should stand for Move On Along.
That's true, buuuuuut is it smart? A push of the nearest button will provide a nearby frequency for ATC or call Flight Watch, where a quick question of ," Is XXX MOA hot?", will yield the answer, even if you're not identified with ATC for flight following. Then, proceed appropriately with the most complete information about the flight, which we are required to obtain.
I, for one, would like to reduce the black eyes that we, as single-engine and/or experimental aircraft pilots, seem to get when someone acts in a way that reflects poorly on all of us, like blissfully barging through a "HOT" MOA when the info is so readily available.
Imagine your response, if a near miss occurs and you're asked to respond to the prohibitions of 91.13 or the requirements of 91.103.
Mike
