We Try..., but watch out!
I use MOAs almost everyday in my military ride, and on weekend's I fly thru them at times in my 'own' ride. But here are a few points to ponder next time you chose to drive thru them unannounced and unafraid:
-Some military jets do have radar, but not all. The typical radar 'sees' 60 degrees left and right of center flight as well as 30 degree up and down (OK, now I have to kill you!) So they are effective looking in front of the flight path only. Unfortunatley, while in MOAs we are NEVER straight and level, in fact moving literaly, in my present case, from 9,500' to 23,000' and back constantly at speeds up to supersonic and climb and dive rates of 35,000' feet per minute. In other words if you, or I, am in our trusty RVs, we could still have a head on closure rate of 600+ mph...not much time to be seen on a fleeting radar screen.
-MOAs do not get 'shut down' when a VFR traffic flies thru. ATC workload permitting, the controller advices us where the VFR traffic is (hope your Mode A/C is accurate???) and we then place a floor or ceiling on that moving target...but remember, we have 'student pilots' /wingman too who probably have a lot less experience in this stuff than you do! You willing to trust your life on them?
-While in the MOA we are generally NOT ALONE. If there is one military jet you see, there is usually another or three or 10 depending on that mission or exercise. Which means that the radars are being used to find those other 'bandits', not set to find/detect Mode C 1200 squawks. If we did set our electronic ID systems for 1200 idents they would lite up like Christmas trees and make finding the bogey, which is what we are training for, able to sneak in the clutter! So while by chance we may find an 'unkown rider' it would be generally unintentional and certainly not the 'briefed objective' of the mission.
-How many of us civilian fliers don't even know if our transponders work well, or for that matter have the Mode C on above 10,000 and funtioning accurately with the right altimeter setting? I can't count how many times I've had a MOA civvie blow thru who was not squawking or talking! And by the way, if you are TCAS equipped, don't get a false sense of security in a MOA, ATC usually only allows the lead military jet to squawk meaning all the other players are on transponder standby or off.
-Many military aircraft are now also TCAS equipped. Just this last Friday I attemtped to ID and avoid another military aircraft (pre-briefed objective) using TCAS only. We found that TCAS gives 'trend info' on tracks and does not work too good on maneuvering targets, so more of a heads up device than accurate pointer. In other words very poor collision avoidance help on a maneuvering target, or if we are maneuvering.
In conclusion, we as general aviation pilots have the 'freedom' to buz thru any MOA we'd like. I've evern heard some guys/pilots boast about how it is THEIR RIGHT and us military pilots are getting paid off of their tax dollars..."so better stay out of my way...." OK, true, but when you get skewwered by a fast mover who probably never even saw you, you're still going to the 'this is what I did dumb' side of heaven! Just three months ago I was RVing up to Kansas and didn't notice I was flying thru a MOA until I came beak to beak with a spinning T-37! I immediately checked my sectional, noted the MOA altitude and descended thinking it isn't worth the risk. Yes, ATC will tell you, if you are talking to them, whether the MOA is active, but work load depending, they may not tell YOU or US that you are even there. Remember, traffic alerts between IFR and VFR aircraft is workload permitting, and as you know, you will generally NOT go thru an active MOA if you are on an IFR flightplan. They don't think its a good idea!
![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
You decide what your pink body, or more importantly, what your passengers lifes are worth, and do a little Operational Risk Management and decide what is right for them! It is a risk and having seen it from both sides, a pretty RISKY RISK.
Good luck, and tailwinds always!
Jj
Building RV-4 Fastback
RV-6
YAK 50
T-37, T-38, F-4, OV-10, F-117
N Texas
