I'm building a 7A with an IO360M1B with the FM150 air intake. I have the new elastomer engine/nose gear mount. The mixture cable from VANs is not long enough going through the firewall per plans drawing.
Has anyone run into this and did you fix the problem by buying a longer cable or did you put a new firewall passthrough on the lower righthand side of the fire wall?
John
John
