As with many builders I am working my way through the trials of fitting an IO-320 in my 9A. I have worked out most issues and am now faced with the prospect of deciding if I should cut my lower cowl to add a blister in the area where the mixture arm rotates - I saw where other builder have done this. My question is how much room should I allow for between mixture arm and cowl taking into account engine start-up & shut down?? Thanks!
