Michael Burbidge
I'm going to use k1000-06 nutplates and AN507-6R6 screws to attach the fiberglass wingtips to the wing skins.
I wasn't thinking and got a little bit ahead of myself. I drilled the skins out to the fullsize using a 28 number drill and then dimpled, before match drilling the fiberglass tips to the pre-punched hole.
I got focused on how I was going to dimple the skins because they are so close to the ribs that I didn't think ahead.
Anyway, now I'm not sure how I'm going to match drill the fiberglass tips to the dimpled holes, since dimpled holes are usually slightly bigger than the drilled hole.
I see three options.
1) Someone gives me a suggestion as to how to match drill using the dimpled holes. Maybe it won't even be that hard to get the hole close enough to center.
2) Flatten the dimpled skins using flat dies in my squeezer. Then match drill and re-dimple. Would I have to worry about metal fatigue?
3) Flatten the dimples as above and then drill new holes in the middle of the existing ones. Then use these new holes to attach the wing tips and fill in the original holes when painting.
I don't really like option 3. It just looks bad, while building. It will bug me every time I look at them.
Any suggestions?
Any suggestions?
