macrafic
I am looking at DWG 27A, and referring to the F-711E down elevator stop/spacer. It is T-shaped. I can see the rivet callouts for the forward row of rivets. However, I do not see a callout for the rear row of 4 rivets.
I appears as though these might be riveted with the elevator rear spar, as there are 4 rivets in each. However, this does not make any sense, since it appears that the elevator is made to be removeable (attached to the fuselage with bolts).
Can anybody help me out here? Rivet now and, if so, rivet callout? Wait until I install the elevator?
