BOHICA Well Known Member Aug 27, 2021 #1 Missed dimpling a hole and most of Horizontal Stabilizer is riveted. Do I just dimple in place? The nose rib underneath is dimpled.
S SantosDumont Well Known Member Aug 27, 2021 #3 get the dimple vise grips. I've also seen people fit the dimple dies in and then use vice grips to clamp down on them.
R rwarre Well Known Member Aug 27, 2021 #4 Dimple vice grips Have used these a couple of times and they work. I might even have mine around if you want me to look.
BOHICA Well Known Member Aug 27, 2021 #5 Spot is easy to get to with my squeezer. So what I am hearing is dimple and build on.
Taltruda Well Known Member Friend Aug 27, 2021 #6 You can still use the simple dies and hand squeezer in there, right?
BOHICA Well Known Member Aug 27, 2021 #7 Taltruda said: You can still use the simple dies and hand squeezer in there, right? Click to expand... Yup. Went quick with no issues. Rivet is nice a flush and pretty.
