mjanduda
Hi Builders,
I'm planning to build an RV-14 (tail wheel) and am wondering what should be the minimum ceiling height of my workshop so you can work comfortably. Also I need to know how big the door has to be to get the fuselage and empennage in and out.
Do you have to fix the gear to the fuselage early in the process? This would result in a higher door. I guess installing the engine and doing firewall forward stuff without gear and attached empennage is quite awful?
What area should the workshop have so you can build comfortably and how much storage space do I need?
Thanks!
Best,
Malte
EDIT: Probably I'm looking for recommended sizes and not minimum sizes! Maybe a minimum size for the door. But the rest should be recommended sizes - I don't want to setup a Hobbit workshop![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks!
Best,
Malte
