So I tried searching and recall others having similar problem.
So the mid fuse longeron needs to be match drilled to the gusset with a #30. I have not drilled mine yet but it appears edge distance is going to be an issue. Have others had issues and how did you solve or just build on with minimal edge distance?
Wanted to match drill this weekend.
Am I correct in stating that edge distance should be 1/4"? it looks like I will only get 3/16 edge distance.
Thoughts?
Thoughts?
