Unfortunately, all the 11:00x5 tubes are "not so good" (that's being polite). I used to change mine every year or two just to be safe, finally installed the Beringer and never looked back. If you ever have a flat away from home, you may regret not changing it to something better when you had the chance.
Recommend you keep it aired up to 40-50psi.
