CharlieWaffles
Has anyone installed a MH Oxygen 4ip or 2ip with or without a dimmer circuit? I wasn't planning on installing an analog dimmer but the MH Oxygen system has a dimmer pin and not much information on how illumination is handled if there is no dimmer on it. I even called MH Oxygen and they were unsure how the illumination would be handled without a dimmer on the pin. I was trying to figure out if I should wire it to power to drive the illumination and use the UI to dim it on the unit itself, or leave the pin unwired all together and basic illumination would come from the unit power lead.
