Hello,
I'm not sure if I interpret correctly manual in this section - connection of resistor on CAN connector.
My configuration:
- 5ft CAN cable to RDAC,
- to be in line with manual I plan one 120 ohm resistor,
- in manual I got information "if single resistor used connect this close to
CAN connector...."
Does it mean close to i-Box on CAN connector or close to RDAC on CAN
connector? Probably close to i-Box but I'm nor sure.
Thank you,
Witold
My configuration:
CAN connector...."
Thank you,
Witold
