The mgl efis comes with these adapters to hook up the pitot static lines:
http://www.mglavionics.com/kb/article/AA-00664/0/iEFIS-Lite-Pitot-Static-Tube-adapters.html
They say that the adapter accepts standard 3/16" plastic lines. I have not found any standard lines with that ID. I have tried 1/4" polyflo and the 1/4" tubing from Stein. I think their wall thickness is a bit greater than 1/32" so the adapters only go a short way into the libe. I have tried dish soap and heating the lines but it diesn't seem to make a solid attachment. What lines are other people using and should the adapter go in all the way up to the end of the taper?
