OK. Does anyone REALLY know the right length for the mixture cable if using a quadrant and the AirFlow Performance Fuel system on an RV-10, AND the best source? Mine has started sticking and I want to replace it ASAP, and would like to get one ordered without having to take the cowling off to measure it. I originally used the green ones from Van's, and have about 220 hours on them.
Thanks.
Vic
Can someone provide the correct method to measure custom length control cables: throttle, prop, mixture. Do you measure from the threaded end to end or do you measure from where they mount, or both. Is there a drawing that spells it out. Thanks
