flickroll
Did an oil change today on my 450 hr since factory new 0-360-A1A. Cut open the filter and in the pleats (mainly on the 'inside corner' of the pleats) there is a small amount of ferrous metal. It is so fine it looks like powder...hard to see unless you look very closely. But it is in every pleat, and a magnet picks it up. The engine had a 2 year hiatus on the wet side of Oregon from 2006 until 2008, although it was filled and run with preserving oil before it was shut down for the 2 year storage. I am suspecting cam spalling/wear. Tomorrow I am going to pull a couple of jugs and peek inside. I'd appreciate any insight from engine gurus on what to look for (other than the cam). Also, since it is a very small amount of metal, should I fly it a while longer and look again in 25 hours? (Although something is obviously wearing). Tomorrow I'll put the magnet inside the drained oil container and see if there's more in there. Should have done that today but I was somewhat in shock....
