XXVI. On Baffles​
Upon an idle engine
A divider to endow,
In shiny sheets of silver
Borders bracing on the brow,
A royal crown for cooling
On the queen of throbbing thrust,
To guard against a galling
Overheated head to bust;
Behold! The angled anchors
Latch the leaves upon the case,
And threaded barrels burrowed
From the fins a bolt to chase,
Where rivet reinforcements
Plying plates into a stack
Do veil against vibration
Lest they loosen, creak, or crack;
Now cut the columns closely
Nesting back behind the fourth,
The frame for hauling heat
From oily oceans to the north,
Where cooler climes do pressure
Past the alleys of exchange,
In foily folds to render
Chilling charges in a range;
At fore with ramps arising
Near a spool of spinning teeth,
With arms of angle reaching
Toward the tongues that lick beneath,
Where sniffing through a snorkel
From a filter at the floor,
The deep induction servo
Needles nectar to the core;
Then comes a paint protection
From a rattle can to coat
Against the heat to harden
On an oven rack remote,
To rim at last with rubber
As a pliable appeal,
Inviting air to enter
Curves the crest a cowl to seal.
XXVII. On Hoses​
For fluids through fittings to flare,
From galleries pumped to a port,
With pressure to pair
For instrument glare
In measurements made from a snort;
From elbows and funnels to route
In rivers of rubber and steel,
With sleeving of doubt
For fire flaming out,
An integral gel to congeal;
Arterial oil in the heat
Arriving unheld in a rush,
With channels to cheat
To plow through a pleat
And coming out cool in a gush;
A venting of vapors and mist
To move through a mile of a vein,
From crankiness kissed
A can to assist
To bleed from the belly a stain;
Transducer in twirly design
Does flick in the flow of a stream,
The leads to align
Supremely supine
What dribbles within to redeem;
Hexagonal humps to a cinch
For leakless the line on a pump,
Then torqued to an inch,
The pipes in a pinch,
To strangle the throat of a stump.
XXVIII. On Startup​
Behold what glory beckons from above
To woo the wingéd captive out her cave,
From dark the dungeon depths of labored love
As born the grounded body from the grave!
With rolling rubber draped in webs of dust,
Where spiders do on spastic reelings run,
There cracks upon a dank and dormant crust
The yearn in yellow streaks of stirring sun;
Now chocked in chilly dew does come the day
When cranked the pistons pump to pressure rise,
To test what silly sensors do allay
A fear from having fallen from the skies;
Anticipation aims an awful hope
Toward Heaven from where gravity does grope!
XXIX. On Flight
From depths no mind could muster
Near the diggings of the dead,
Where piled upon depression
Grows a steeper grave instead,
A mountain made of anguish
On the angle of despair,
From pebbles poured of shovels
Through a thorn of shackled air;
Awake, O idle engine!
Join your pistons to the prop!
And spin a fanning fury
Twisted tentacles to drop,
With weight of ored emotion
Falling fetters from the wings,
Away the chocking wedges
To uncheck what bounding brings!
O throttle, raise a thunder!
Let the rumble loose within!
Unbridled be the horses
Hunting down the drag of sin,
In quad the crank to gallop
Gives a gush of powered birth,
And pangs of peeling runway
Blurring by the break of earth;
Rejoice! Oh, jubilation!
Sings the soul around the rise,
The Anthem of Ascension
Naming notes to scale the skies,
A launch of escalation
Looking down upon a height,
Where home unheavied burdens
Bear the falling float of flight.
Epilogue
Now do these meager meditations meet their end, and with the whistle of airspeed and the splatter of bugs, the eighteen-month odyssey of aircraft upgrade finally reaches home—this, on the 82nd Anniversary of the D-Day Invasion of Normandy. What adventures now lie before us? What callings now come from the shades and shallows of a world that so begs for exploration? With just a few hours left on a second Phase 1, and with the invitation of summer now sliding through the door slot, the answers remain to be seen.
