Looking for a little insight. Maybe one of you has dealt with something like this before. I am getting ready for the first flight and in ground run ups the mechanical fuel pump is not delivering enough pressure to feed the fuel injection system and the engine is quitting. It seems to run OK at low RPM, but when brought up to medium power it quits. We finally got it anchored down today and did a full power run up and shut off the boost pump once it was there and we were getting 27 psi of fuel pressure with only the mechanical pump. When the throttle was reduced the pressure quickly dropped to about 15 and the engine again quit. Any ideas?
Mike
RV4, CA
Mike
RV4, CA
