OK, tried reading search results for an hour with no answer for this, checked several builder sites and I can't find anything in my engine manual or the plans that covers it.
I have installed the yellow plastic tubing that fits over the short copper tubing of the fuel overflow valve on my mechanical fuel pump. That mechanical fuel pump is attached to my IO-360 engine.
I'm not sure under what conditions fuel would need to escape through the mechanical fuel pump overflow line. Regardless of that, I don't want that yellow plastic tubing anywhere near my hot Vetterman exhaust pipes.
Is fuel overflow through the overflow valve on a mechanical fuel pump a common event?
But, most importantly, how and where have you routed the yellow plastic tubing to the exterior of the aircraft in a way that avoids the heat from the exhaust?
As usual, thanks in advance to all the experts out there for your help!
Albert Thomas
N880AT
RV-8A QB
Almost ready for the DAR
Albert Thomas
N880AT
RV-8A QB
