HFS
Anybody used this - and if so what results?
For an already installed system, would you remove it, separate all the parts, lube per directions & re-assemble; or, would you dilute with MEK (or equivalent) and "soak" the joints as best you can?
Thanks for the response - I already have a can and plan to use it, just trying to get the best performance with the least amount of maintenance anxiety.
HFS
Great stuff. All I use. No graphite. This stuff lasts much longer the Mouse Milk. Typical McFarlane product, works as advertised. If you have the ability to separate the parts, it's always good. If not, D.A.M. will capillary into the joint. Use liberally right out of the can. Don't thin.
I tried it from the samples they handed out at SNF.
Didn't care for it.
Seemed similar to Mouse Milk.
I normally like to disassemble and use Nickle paste and work the joints.
Just my 2 cents
