The reason you don't see a lot of McCauleys on these airplanes is because they don't try to make the experimental market theirs. The don't sell new any kits for aircraft such as the RV. There are some things to consider:
Mooney 201 and Cessna Cardinal RG both use a similer prop on the IO-360 A1B6 or A3B6. Of course to get this to work well, you will need to use the spinner from that aircraft as well. The little bitty VAN's fiberglass spinner doesn't fit I don't think. The spinner bulkhead combo from the Mooney or the Cardinal is a bigger diameter, therefore you will find yourself needing to modify the cowl to some significant degree to get the fit.
The advantages, if they can be call that:
*Unique, not many people have this combo, maybe conversation.
*COULD be faster, but I doubt it would beat the BA Harzell
*Lower overhaul cost, Lower parts count, a ONE piece hub.
*Spinner looks NICE on RV's
There was a Turbo -8 in SportAviation a couple years ago that used a three blade McCauley. Obviously the owners weren't worried about weight with the 3 blade (At 73.5 LB installed weight) and the turbo, but the McCauley longer pointed spinner looks WAY better than Van's IMHO
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If you have a deal on one, I'd go for it, otherwise, stick with the tried and true. It's hard to be the Hartzell BA value.
