Carl Froehlich
I?m helping a budding that is still flying off his 40 hours in his RV-14A. He is using a custom composite prop. The prop leading edge is starting to bubble so the prop manufacture is going to replace it. The current prop is 24? in diameter. The question is can a 26? diameter prop be safely used instead of the 24"?
