I did a max fuel burn rate test on my O-360-A1A for the AirVenture Cup Race today. It is a 407 nautical mile race and I have 36 gallons usable with the tip tanks removed for racing. The only thing of interest here is at 2720 RPM, 3,000 - 3,500 MSL, MAP 26.5 - 27 (respectively), OAT 29C, leaned for 1300F hottest EGT, the test fuel burn rate was 14.5385 gal/hr.
From years of flying this and several other stock O-360-A__ Lycomings the 75% burn Rate is a solid 10 gal/hr.
If you are curious the, the ground speed required to make the 407 nautical mile trip with a half hour VFR reserve AT FULL POWER is 206 kts. With no reserve the speed required is a little over 164 kts.
Bob Axsom
Bob Axsom
