tx_jayhawk
I just finished installing the Matco RV axle, and I had a few questions that were not sufficiently covered in the instructions:
1) With the pre-loaded bearing torque that is provided, how tight do you torque the axle nut?
2) How tight should the 1/4" retention bolt for the axle be...standard 1/4" torque?
3) The instructions show to "static balance" the wheel using 3/8" threaded rod and two cinder blocks. I slowly spun the wheel and could not tell any heavy spots, but I'm not sure how the static balance is supposed to be done, but I'm just guessing.
THanks,
Scott
7A
THanks,
Scott
7A
