It states;Have a read "kit Airplane Construction" page 336 -337
Well, the pilot hole for your dimple dies is #40, so they will not fit in ahole you haven't match drilled before. It a very useful reminder of missed holes when you dimple your skins. When dimpling skins, if the dimple die is somewhat reluctant to enter a hole, don't push hard , back off, locate the matching hole on the other part, ream both holes with #40 reamer and THEN continue with dimpling.When dimpling, drill the appropriate pilot hole for the dimple die, dimple, and then drill to final size.
