LAMPSguy
The ailerons use a steel tube for a mass to balance them. I am directed to cut it to a specific length. But what if someone does not prime inside? What if I heavily prime? Obviously the weight is small, but is must be significant enough to measure I would imagine.
Any active aero engineers that can answer this? I can't find my old text books and those classes...well...they are a bit fuzzy!
I imagine the tiny weight differential would/could be offset by trailing edge geometry. Just curious, not worried!
