Z Zazoos Well Known Member May 7, 2018 #1 0-320 with Marvel Carb. I am searching for bolts with drilled heads to attach the FAB. Standard AN bolts are the wrong thread pitch. Needs to be more coarse thread. If you know a source I would really appreciate it. Thanks in advance.
drill_and_buck Well Known Member Patron May 7, 2018 #2 i got mine from Van's. Give them a call and they will take care of you.
B Bcone1381 Well Known Member May 7, 2018 #3 AN bolts have fine pitch threads. You want a course pitch threaded bolt. You might try an MS20074 bolt. Its a drilled head "engine bolt" available at Aircraft Spruce. http://www.aircraftspruce.com/catalog/hapages/enginebolts15.php
fl-mike Well Known Member May 7, 2018 #4 drill_and_buck said: i got mine from Van's. Give them a call and they will take care of you. Click to expand... Yes, they are in the hardware section of the catalog.
