77bonanza
Active Member
Manual Trim Elevator Wheel / Defrost Fan
Has anyone installed a manual
Elevator trim wheel in the RV 14? If so, I would be interested in how to.
Also, I intend to fly IRF and have a need for a defrost fam to remove ice that my accumulate on the windscreen. Does the existing defrost features on the RV 14 have this capability?
Thanks for your help!
Has anyone installed a manual trim wheel in the RV 14? If so, I would be interested in how to.
The kit supplied fans are not promoted as being defrost fans. They are de-fog fans. They would not be capable of removing anything frozen (like frost) and especially not ice accumulation.
Run Away!
If you find yourself in icing in a recip, your first concern should be to exit said icing ASAP!
Don't lead yourself down a Rosy Path! Playing with fire here
I installed Aerosport?s trim on my 14 for rudder trim. I like it and it works OK
