S skidookid Active Member Jun 20, 2019 #1 Rv 8 with manual elevator trim play. Has any body put spring on trim tab to hold cable tight and possible get rid of slack in system
Mel Legacy Member Mentor Jun 20, 2019 #2 skidookid said: Rv 8 with manual elevator trim play. Has any body put spring on trim tab to hold cable tight and possible get rid of slack in system Click to expand... Yes, I have seen a few. But I couldn't tell you who it was. I see a LOT of RVs. to the best of my knowledge it works fine.
P pilotmansam Active Member Jun 20, 2019 #3 I have the same problem. Play in the trim tab. How would this be done?
A alpinelakespilot2000 Well Known Member Jun 20, 2019 #4 Although generally not deal, play in a manual trim tab is very normal, well documented in the archives, and indeed is something Vans has confirmed as normal.
