freegespeed
Active Member
I have already read Sam Buchanan's nice article on his choosing to convert to electric flaps after he started with the manual ones. I was wondering if any one else has any more to add about this modification? Does the motor move the flaps fast enough? Is it hard to install?
I have the manual flaps on my 6A, which was the builders choice. I have about a hundred hours flying in my machine, and the manual flaps seem a bit cumbersome. The 10 and 20 degree settings are smooth, but the 30 degree one seems to take some muscle for some reason. I intuit that increased aerodynamic forces are probably the reason. I always slow down to the white arc speeds.
The issue with increased flap lever resistance can interupt part of my pattern flying skills, resulting in a momentary irratic main stick movement while setting the flaps . This situation is just a short few seconds, but I would prefer a smoother action.
I can easily deal with manual flaps, but the idea of hitting an electric switch like on the 172's (yuck!) I used to fly sounds appealing. Not to mention the added space between the passenger and pilot.
Any help would be appreciated.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
