Make sure to include some type of restrictor to smooth out the power pulses. Otherwise the timing will bounce around.
You can see this happen on our EICommander, so it is not just theory.
Somewhat related question - I have both pmags looking at MAP from the 1/8" copper line that used to be the #4 primer. Is that enough restriction or should I put something else in place?
Or, more broadly, what size restrictor would you recommend?
