Waylon, I believe you are asking about painting the entire spar, correct? I just painted the upper and lower flanges, kind of like Ron, but just shot the entire flange with paint. After completing most of the wing kit, ailerons and tips left to go, I can't really see how painting the spar would be an issue if that is what you want to do.
I just sprayed the top flange where the wing skins joined the spar. It took 10 mins.
Cheers Jim
