chrishalfman
Active Member
I am fitting the main gear pants on my 7A and was wondering if anyone had used screws/nut plates on the U-808 bracket (the bracket [flat strip bent kinda like a ?V? with flats for the pant connection] from the axle nut to the wheel pant) instead of the rivets? I?m sure the rivets look nicer cosmetically, but wouldn?t the screws allow the pant to be removed somewhat easier than getting in on the bolt that goes into the axle nut? Plus, getting in there to safety the bracket cap screw in the nut to the axle cotter key would be a lot easier. Or, is there a good reason not use screws and nut plates on the pant? The inside bracket uses screws and nut plates. Or, is it really not that bad and I'm just whiny. ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
