Av8torTom Well Known Member Jun 13, 2018 #1 Hello - where are people mounting their main electrical bus in the 9A? Thanks, T.
JohnInReno Well Known Member Jun 13, 2018 #2 Fuse blocks I used fuse blocks for the main bus and mounted them on a swing down panel on the passenger side.
Robert M Well Known Member Jun 26, 2018 #3 JohnInReno said: I used fuse blocks for the main bus and mounted them on a swing down panel on the passenger side. Click to expand... I did basically the same thing. I used smaller ones, a total of (5) 6 port fuse panels. I have them on both sides, hinged under the panel. This allows me a little more room to get by (if needed) to other "behind the scenes" work. Robert
