As I understand it, normally you would use the T150 e-gap tool or the T-100 timing jig to set the e-gap [ie; points just opening].
I am thinking that you could also use the appropriate L or R pin-in-place holes [for the T-118 tool] to locate this same reference position since it also appears the be the point at which the points are just opening.
Is this typically the case?
Bruce
Bruce
