Mu-metal will interfere with a magnetic compass
I used to design mu-metal shields and I have some understanding of the material. I think I can answer a few of these questions. Mu-metal re-directs magnetic fields, it does not attenuate or trap them. A magnetic field cannot be shunted to ground like an electrostatic (voltage) field can be. A magnetic field likes being in mu-metal better than almost any other material. It enters the mu-metal and can be directed by the mu-metal shield, but it will eventually come back out of the shield somewhere and end up going in approximately the same direction it was going before it was intercepted by the shield. The exact behavior will be dictated by the various magnetic and voltage fields in the local area of the field. In your situation, your compass should be being shielded from any voltage fields, generated by the EFIS and other equipment, by the metal glare shield and the housing of the EFIS (both grounded I assume). If you wrap mu-metal directly around your compass you will get erroneous results from it if it works at all. You could try to shield the EFIS's magnetic shield with a mu-metal sheet or box over/around the EFIS, but that magnetic field IS going to come back out of that shield somewhere and will likely still disturb the compass reading. The distance of 1 inch is
way to close to any high current carrying device. Distance is about your only solution with magnetic fields, for a magnetic compass anyway. I am sorry for your trouble, but I am going to learn from it. I
was going to do the same thing: place a big EFIS tucked up tight to the glare shield and place my magnetic compass right over the top of it. I no doubt would have had the same problems you are having. Can people comment on where they have successfully mounted the magnetic compass relative to EFIS's ? (and other gear)??. Especially for the RV-8.
Other fun facts about mu-metal. It must be fully annealed for it to work well. Cold-work: bending, folding, cutting, forming, even banging, disrupts mu-metals annealing and dramatically lowers performance. It must be annealed in a hydrogen, or inert gas atmosphere furnace. Mere mortal DIY'rs are unlikely to have one of these
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. If you do get mu-metal mail ordered from someplace like ACS, it is likely to have been fully annealed
prior to shipping. You should minimize the amount of bending and banging it receives during your fabrication in order to maintain as much of its "annealing" as possible. Also, thin layers are not "better", it is just that thicker doesn't work any better than thin. A layer of mu-metal can only absorb so much magnetic field density and this is independent of thickness. Another layer can carry any field that could not be absorbed by the first layer(s).
Kerry Stevens
