I will be installing a vertical card magnetic compass in the panel (Precision PAI 700), together with a Skyview and an SL40 radio. How close can the compass be to these electronic gadgets without risking interference from their magnetic fields?
I have been struggling with this deciosn also. I thought the regs required a magnetic compass for IFR flight. I too have a dynon d6 and also the garmin g3x. Both have electronic magnetic compasses. Because they require power to operate, do they qualify for the FAR requirement?
Sorry, I can't answer your question due to not having personal experience with that particular combination of avionics.
But.....why are you installing a magnetic compass in a panel that has a Skyview? You may have a very good reason, but the Dynon has a fantastic heading indicator--far more reliable and accurate than a mag compass.
Robert the magnet in 700 is somewhat different from regular Whiskey and behaves better I heard. Why not to power on all your electronics and test deviation on your compass empirically? You may be surprised of performance just an inch from your SkyView.
Thanks Sam. A backup magnetic compass is a CASA requirement in Australia. Otherwise I probably wouldn't install one.
While it's not required it is one of 2 gauges that we installed (the other was AS) along with an oil and alt light...
Because, if you have a hardware failure ... you can't look outside and see how fast you are going and you can't always tell what direction you are going....![]()
flyboy,
My compass was 50 degrees off on some headings when it was mounted right beside the electric T&B. Swapping the compass with the instrument just to the left of it makes it accurate on all headings. Next to the altimeter should be fine.
Also, you might check your control stick and other steel parts in the vicinity of the panel. My stick and canopy bow were magnetized.
Not if you don't have a valid GPS signal...Wouldn't a battery powered GPS be far more useful than a mag compass?
