Hi all,
Recently had my conditional inspection by my local AP/IA. He called and asked whether the mag timing should be set at 25 degree's or 20 degree's. I have an ECI 0-360 A1A with 9:1 pistons with Slick mags. The engine doesn't have a data plate for timing references. Historically it's been set at 25 degree"s. He called ECI and they said that with 9:1 pistons the timing should be set at 20 degree's. So that's what we did.
Now, flight testing indicated a slightly slower TAS (167 kts vs 172 kts) but slightly cooler cylinder head temps (320 vs about 340). This is after about 1 hour of flying. I'm not concerned about running with a slightly higher cylinder head temp but hate to lose 5 kts. I will re-check the performance but was wondering if anyone has a different opinion or different experience's.
Regards
Regards
